Well, it had to happen. You finish one build & in my case, my first, then you start to think about what you're going to do with all the bits left over & the next minute you're planning the next one !
So, here's the first big lump, the forks. It's going to be much the same as the first Métis I built with the same front perimeter brake setup, but with Leafer front forks instead of Springers, narrower rear wheel/tyre (200 at the biggest) & slightly more ground clearance (maybe an inch ish).
Engine wise I'm really not sure yet. I might use another S&S 93" P-series Panhead, or an Indian P100, or even a modern Indian Scout engine. I'd really like to use another Morris magneto too so that might limit engine choices. We'll see, I don't have to decide until I order the frame.
https://www.v-twinforum.com/forums/attachment.php?attachmentid=244214&stc=1&d=1548171938
Hopefully it won't take ten years like the first one !!
