1 - 13 of 13 Posts
Fellow on another board just did one for his OL. He cut the fork tubes and remachined the grooves for the retaining rings and cut the springs. He used shorter shocks in the rear. If you want I can give him your e-mail, so you can ask him in detail.
Ralph,
lowered my superglide about two years ago. What I did was install progressive suspension's front lowering coil springs in the front forks (2 inch drop) and went to 11 1/2 rear shocks in the rear. I am 5 11" and can now touch the ground flat footed. It also looks cool.
G
Bry2403, I assume you mean five foot one inch, not five foot eleven inches, correct? Flatfooting a stock Dyna (even the tallest one, the FXDX) should be nolo problemo at 5'11" ... ;)
G
I took about 1-1/2 inches off of my wife's bike by taking off the seatcover and shaving down the foam with an eletric carving knife...
what did you do to lower it
What did you end up doing to lower your bike. I'd like to lower my 2003 FXD so I can plant my feet on the ground better (27" inseam). I'm not sure how low I can go because I'd like to ride 2 up some.
1 - 13 of 13 Posts
