Ok here is the list, not in any particular order and some with HD part numbers. All will be going to Ebay some time soon.
Send an offer if you are interested. I am taking the pictures today (I hope) so just let me know if you want them
Thanks,
Kevin
Heavy Leather Biker Type Jacket (New, never worn) Size 48
Leather Fork Bag, round, used but still in very good condition(SOLD)
57748-04 HD Detachable Tall (1 inch cut off of the top)Windshield for softail with auxillary lights (off of an 01 FLSTF) Used in very good condition, no scratches, some very fine scratches, can only see when the sun hits the right angle.(SOLD)
HD New Heritage Leather Saddle Bag with studs(SOLD)
76326-00A Antenna Relocation Kit for Touring, New In box(SOLD)
HD Softail Chrome Upper Belt Guard. Very good condition. Off of an 01 FLSTF(SOLD)
67178-95A Speedometer for Sportster 95,96 New(SOLD)
31775-01 Screaming Eagle Ignition Module, (SOLD)
27414-99A HD CVK carb with Thunderslide kit installed. Has around 500 miles on it and was stored properly. (SOLD)
S&S 79cc Super Stock Heads. 90-1053FT and 90-1053RT They have titanium collars and can take up to .640 lift. they have about 3000 miles on them and they are in very good conditon. They are Black.
(SOLD)
HD Oil Cooler Adapter with thermostat, for Softail or Touring Twin Cam(SOLD)
HD Stock 01 FatBoy Turnsignals, front and rear, new take offs.
HD Lower Fork tubes re-drilled for FatBoy Fender, setup is for converting a FLST over to dual Disc Brakes,using stock calipers.
HD Wide Tire Caliper and Stainless Steel spacer for 01 Softail. should fit more years. The Caliper is a new take off, you still need to shorten your short spacer by the amount of difference in the long spacers. (SOLD)
S&S Adjustable Push Rods and Tubes, New in package 93-5095, DS199236 For Twin Cam(SOLD)
53810-00A HD Detachable Side Plates for Softail (HD book, 2000, later) used very good conditon(SOLD)
HD Softail Dash, used in excellent condition off of a 2001 softail(SOLD)
91001-01 HD Skull Tank panel, used in very good condition
68319-01 HD Smart Siren for Softail. This is the Siren only not the kit, the missing part is a bracket, which I did not use anyway, just a couple of wire ties worked better.
69287-05 HD Auxillary Driving Lamps, used in good condition, Comes with an extra lamp. you still need to get the docking kit.(SOLD)
65526-98 HD Chrome Exhaust Bracket, Softail up to 99. This is the bracket that most aftermarket exhaust manufactures require you to purchase to add their exhaust systems to 2000 and later Softails.
I still have some other misc stuff as I continue to clean out the garage...
Thanks again,
Kevin
Thanks,
Kevin
(SOLD)
Thanks again,
Kevin
