Went to go out on my bike yesterday went to start it , turns over not firing.
So checked to see if there was a spark no spark . Was running fine up till that point . Any ideas . Thanks
Lots of possibilities,,
First check for codes,, and test the circuits,,, indicated by the codes retrieved..
Do you have the electrical service manual? Having all 3 manuals, makes diagnosing and repairing issues much easier.
If the engine is turning over, the kill switch is generally ok.. inside the switch housing, is a jumper between the start switch and run/stop switch..
Check for 12 volts on the center terminal at the coil,,, it is a 3 wire connector,, toggle between stop-run, and watch the meter,, on=12 volts, off= 0 voltage,, if so,, the switches are functioning properly.
