Okay trailers. Be sure to check approach angle of the ramp door. Sometime a pain in the butt especially if bike is lowerd. BTW same roof editor from the diesel stop?
Generally if you go with a 7' wide trailer approach angle will not be a problem because the wheels sit out from under the trailer. If you go with a 8' wide trailer you will run into problems depending on the bike. Stock 03 roadking loads fine and a 02 fatboy. A lowered 02 roadking will scrape along with my street glide. I use the trailer to haullsnowmobiles and bikes. I went with the 8' because it make for a shorter trailer when trying to carry three snowmobiles.
