www.deweyspegs.com
Call Dewey at Dewey Customs. Lots of satisfied customer right here on the board. A lot more bang for your buck.
Be sure to do your homework before buying the 37G. The 37G in an 88" will give you impressive numbers, but probably not where you want them. You said you were not going to be going to the track, and that you wanted "get up and go at the throttle". In your 88" with the 37G, the gain you get won't happen until 2200 rpm and up. You also need 9.7-9.8 cr for this cam to shine.harleymike77 said:Just an Andrews 37 cam, add the Power Commander III USB, and a Dyno? This is starting to look pretty good! As you're aware, I'm not very mechanically inclined, and I TRULY appreciate everyone's assistance on this. I would be willing to stay with the 88, and just do the above. I'll have to research into the Andrews 37B Cam, and find out the best place to buy one. This may just be the way I want to go! I'm just looking for that "little extra bite".
Thanks everyone for the info! I may start at the above route, and as time (and $) start piling in, do some more mods (heads etc.). I think in the interim, this package may just do it for me! Considering I just dropped a mint on chrome, this route may be cheaper than a divorce!
Where does this maddness end? I thought I would be happy with a "stock" 03' FLSTCI................Well, after dropping close to $8,000 already on mods................it's an addiction............I think I need a 12 step program!
Seriously, thanks again for everone's help on this, i appreciate it! RIDE SAFE.
Mike
YankeeBob,YankeeBob said:Be sure to do your homework before buying the 37G. The 37G in an 88" will give you impressive numbers, but probably not where you want them. You said you were not going to be going to the track, and that you wanted "get up and go at the throttle". In your 88" with the 37G, the gain you get won't happen until 2200 rpm and up. You also need 9.7-9.8 cr for this cam to shine.
A 26G will come on around 1800 rpm and works well at about 9.4 +/- cr.
Do what you want, just don't jump the gun. Talk to the experts.
YB
harleymike77 said:Just the Andrews 37 cam, add the Power Commander III USB, and a Dyno? This is starting to look pretty good! As you're aware, I'm not very mechanically inclined, and I TRULY appreciate everyone's assistance on this. I would be willing to stay with the 88, and just do the above (would the SE 203 cam be better?). I'll have to research into the Andrews 37B Cam & SE 203, and find out the best place to buy one. This may just be the way I want to go! I'm just looking for that "little extra bite".
What do you think?
Mike
From Andrews website:wkohn said:YankeeBob,
What about the 31G cam with a .030 head gasket?
Bill
I'm planning on head work anyways. Just trying to decide on a cam. Woods, Andrews, Head-Quarters, Crane, etc, etc, etc......YankeeBob said:From Andrews website:
Great cam for motors with 95+ inches and 10:1 CR.
Lower TDC lift means easy installation. Similar to 37G
but different timing. 2000-5800 RPM power range.
Note the 10:1 cr. Read...$$$ headwork.
YB
