It looks like the seat is held on with a bungy cord,, not good craftsmanship on an ugly seat to boot..
The exhaust is a huge power burglar.. If mine, I'd cut down and slip-on some slip-on muffs..
Good wheels and Gma rear brake.. It doesn't get better than that,, it gets as good but Not better..
Even in poor tune it'll often start with a button soo, I'd request the "Expert" in charge to kick-it alive.. If it won't start,, it needs Goood tuning that apparently they are not capable of..
It Must start & run or deduct deduct deduct.........!!
It has a Narrow-glide.. Easy to change to Wide-glide, that would be up to Your preference..
Lift the front end to feel it's Fall-away and neck bearings and wiggle the wheel bearings..
Lift the rear and spin tire, listen for grinding or unusual sounds from the primary area and Tranny..
Wiggle the bearings..
I'd request inspection of the Primary chain & sprockets..
Look at the rear chain & sproc's..
Easy to replace,, just costs..
I forget already,,, is it Fat-bobs or a single tank.?
If Fat-bobs,,, with a light, peek down in the rear Gas tank mount area to spot if the tanks have been welded on around the Stud or even poss a wee wet from a leak.. If wet,, deduct 500.. If welded on be prepared to weld again.. That is almost one a those probs where it is "when" not "if" it leaks.. It's the weakest link in the old shovelhead chain and HD should be ashamed of themselves for it's poor craftsmanship..
That split/leak can be managed with correct spacing and shimming when mounting the tanks..
It's a swingin-arm and I only build Rigids so I cannot comment on what to be aware of with those barka loungers..
Poke at stuff and wiggle stuff, look for looseness that prob shouldn't be there..
If poss,,, when it starts, ask for an Intake Leak spray test..
If there is a leak it certainly is Not a deal breaker cuz it's easy as falling down to fix,, just good to know that it's there or Not..
That motor should have O-Ring intake seals..
I consider them the best seals HD ever used but require a wee bit a practice to install..
I have not had to mess with my O-Rings in about 6 years..
It should shift easy and find Neutral in a nano-second from 1st or 2nd.. The foot shift lever should snap back to center, if not, the ratchet-top needs attention or something's in the way that should Not be..
Foot-board brackets should be tight and Definitely look close for frame cracks,, you know,, that's a given..
Those NADA and Kelley and Edmunds prices are based on OEM units,, Not on tweaked "modified/customized" sickles..
Be prepared to offer waaaaay low and do Not be fooled into a high price for a "fresh" motor cuz you simply don't know WHO built the motor and how good they built it,,,, go after it as though the motor had 80,000 on it..
Looking at it again heck,,,, I bet they'll be happy to sell it for almost anything..
OK, I just saw the price,, I'd say get ready for some old fashioned horse trading, Buck-a-roo........
Bring cash,, the seller won't want to see that cash walking away if ya know what I mean.... Me,, I'd begin at 3,800K & walk at 4,800,, and that's even if I found everything fairly OK.. It's the economy..!
[email protected]
