I have an 02 Electra Glide standard, need to know where the tranny drain plug is located. I had a picture diagram saved from a post on this forum of all the drain locations, but it is now a dead link.
Thanks for any help.
do not have a pic but there are 2 drain plugs close to each other underside the engine. The forward facing plug is the oil drain and the plug facing down is the tranny drain. It is closest to the frame crossbar and uses a 5/8 wrench.
The Anti-RUB
Can't stress this enough: Get the service manual. It will tell you all you need to know... and then some... Worth every penny... Good luck...
