I just put a set of samson true duals on my 03 rk and have noticed the rear muffler and pipe moves around a good bit. there are no exaust leaks. is this something I need to be concerned about? should I fabricate a rear bracket similar to the factory?
Yes, or you will always have that problem. I'd never buy a true dual system unless it came with the left header pipe support bracket that mounts on the starter to inner primary bolts.
Thanks I still have the factory parts but due to the bends in the pipes it will no longer work, but I work for a full mfg company so I will just design and make one
