What if you adjust the idle mixture screw all the way until it's gently touching the seat, but the engine doesn't really stumble?
I made sure my bike was good and warmed up (rode about 45 min) before I made any adjustments. Couldn't seem to get it to stumble on the lean side (not like when I used to play with the Holley on my old truck). Went back to approx. 2 1/2 turns out for now. Checked the mileage, seems to be around 39mpg, and seems to run good & strong.
I changed from a 45 to a 48 slow jet a while back (after installing a K&N air filter & slip on mufflers), but did no other mods to the carb (except the idle mixture plug).
Is this a problem or am I paranoid? I want to make sure it's right, so I don't have to keep messing with it.
Thanks in advance for your advice
