I have a 2001 Deuce with 17,500 miles. Noticed the other day that the return line coming out of the engine is leaking (quickly). Without a doubt, the oil is coming from the O-rings on the outside of the line and also inside the chrome nut/fitting.
I have taken the line off, and replaced the O-rings with brand new ones.... twice..and new clip. Oil is still leaking. I have also tried O-rings that are slightly larger then stock, thinking that it may seal it better....and no luck at all. I have taken the line on and off probably 8 times, with different combinations of O-rings, and NOTHING WORKS.
Advice? I need it bad. Harley techs just keep saying they have no other ideas..... How can this not work with brand new rings? I can't believe it ever worked to begin with. Seems like a horrible design. I have no clue where to go from here other then buying a new chrome fitting and line (at $40 a piece)...although I cant see how either of those two could have gotten damaged. Theres certainly no visible damage. Also, the original O-rings that came out of it are in perfect shape..no damage whatsoever. PLEASE HELP!!!
