Hi there!
After having procrastinated on doing an oil change myself for way too long, I finally had no more excuses. I have a service manual and an oil filter wrench and I went for it.
Besides beginning by using a Torx bit instead of a hex bit for the drain plug (it seemed to fit so well until it slipped...) it went alright. I did make a pretty good mess, but I guess the learning curve on this is pretty steep and I should be ok next time.
I cleaned the mating surface,oiled the gasket and spun the filter on. I tried using my hand to tighten it, but having greased up everything pretty good and having nowhere to wash my hands close by, I couldn´t budge the filter as soon as it barely touched. So I used the filter wrench to tighten it to the "book" value between 1/2 and 3/4 turns after touching.
So far so good. I rode the bike through the garage for about 5 minutes and let her idle for another two and checked for leaks.
So- it leaks. No gushing leak, but I had a pretty good puddle under the filter (dollar bill size maybe).
Now I feel like a total left handed nerd for writing this lengthy post on something as simple as an oil change, but what to do now that I have a leak? The filter is surely on tight enough- maybe too tight.
Should I tighten it some more?
Loosen it?
Try again and replace the filter?
BTW, if I change the filter with the oil tank full (Softail), will I get a major mess or will it be about as much as taking it off with an empty oil tank?
I´d appreciate any tips you can give!
Sponk
Loosen it?
Sponk
