I have an analog one and it's pretty accurate, the LCD is just as good but you wanna get the second generation (a new one from the past 6 months) as the first batch where failing from the heat.
That said, remember this is just the oil temperature of the oil in the sump, not what the actual temperature of the "jugs" are. You can figure out your averages, and when something unusual occurs you will be warned. Just try and look at it when you are riding, on my Fatboy with my seat it is pretty tricky… ;)
If you don't mind spending over three times the price for it over the dial version, and you like it. Go for it. It will NOT be 3X more accurate or be any more functional than the analogue. So your money buys a gadget and cosmetics.
Discussion Starter · #6 ·
So is this what you guys are using when you say your bike is running at 230 degrees or are you checking the temp some other way?
