I have a 2001 Superglide with the cast wheels and found a set of used laced wheels from a 2003 Softtail Standard 21" front and 16" back for sale.
Will these fit?
The back is wider 150 vs. 130 that is on my bike now and 21" vs 19" for the front without relocating the front fender?
I also found a set from a 2006 Low Rider but the back is 160, which I think is too wide without modifcation.
Any help will be appreciated.
Craig
The rear will fit, front won't
The rear wheel will fit but the front won't.
The rear rim is the same width but be sure if you use the 150 rear tire that the fender bolts don't rub the wheel or just use a 130 tire.
As for the front, you need a 21" front wheel from a 2000-2004 Sportster custom. It will fit right on without any problem.
I thought the rear might fit, but I didn't think the front would. It's good to find this out before buying the wheels.
Thanks.
