I'm considering upgrading the stock mufflers to Khrome Werks HP slip on mufflers for my 05 FXDi this winter. At the same time, I'll be puttiing on the Arlen Ness Big Sucker air cleaner (or SE...not really fond of this one).
1. Is there a difference in sound between the tappered version and the Bologna version? It seems like since the Bologna version has a larger opening, it would be louder, but I'd like to know if there actually is a difference.
2. I haven't found (when I did a search) a whole lot of comments on THESE pipes (except from like two people)...so if you have them on your ride, sound off, I'd like to hear from you!
3. I'll also be putting a DFO or PCIII on to make sure that I'm not running lean, instead of doing a ECM flash...I don't really ride above 5000 RPMs, so the flash probably won't do me a whole lot of good if I do one or the other.
Hopefully this won't run me too much more than $500 if I do everything myself.
Thanks!
:beatdh:
Thanks!
:beatdh:
