Use the accessory circuit, and put a fuse in the line.. If you use the headlight circuit, you'll have too much amperage on that circuit, and you surely don't want a 50 amp fuse for that.:chopper:
you should run the amp's main power wire to the battery (with a fuse) and hook the amp turn-on wire (usually blue) to the bike's accessory lead (also with a fuse)
