· Registered
So, the question is, both Kerker & Harley have slip on mufflers for the touring models that require the purchase of end caps. I like the fishtails, Harley sells them for $129.99 a pair (minus my 20% discount), = $104.00 for the pair. Kerker/Supertrapp, want $99.EACH! = $200.00 for the pair! They look identical in appearance, does anybody know if the Harley end caps are "interchangeable" with Kerker? Will Harley end caps fit on the Kerker mufflers?
· Sniper
Don't know if this helps but SuperTrapp made the Harley Screamin Eagle slip ons for Harley for quite a while. SuperTrapp still sells them I believe on their site under the "SE" model name.
· Registered
ha ha...i went thru the same ordeal of trying to figure this portion out when researching the model/manufacturer of the SE slip-ons currently installed. purchased the bike used, so yeah I've been trying to find out all that i can about it.
On the Supertrapp/Kerker website they state which will fit the SE line in addition to theirs, they are one and the same.
You can also find other manufacturers that make end caps for the SE line of pipes.
Good luck...and remember, I only speak of the SE line and am not entirely sure of the stock pipes.
on a side note...http://www.supertrapp.com/product_sections/cat.asp?CatID=43 = SE Slip-Ons
http://www.supertrapp.com/product_sections/cat.asp?CatID=73 = End caps for the SE Slip-Ons
