I was out riding this weekend and I noticed my 89 FXR kept missing forth gear, when I say missing I mean I shift up to it and it does not engage, I double shift it and then it shifts into gear. This is a 5 speed.
This just started this weekend, and I checked the fluild and it is ok I think. I screwed the cap down and it shows to the full line, Should I be screwing the cap down to check the fluid or just insert the dip stick without screwing it down.
This does not appear to be a clutch issue and the clutch is working fine.
This is only happening when I get up to forth gear.
Any suggestions would be appreciated.
Yes I have a manual and I read the part about adjusting the trans but would like to get input prior to tearing into the trans.
Troy
Discussion Starter #2
Sorry failed to use the search function first! :huh:
nevermind guys, I did a search and found what I needed, I will try the pawl adjustment first and see what happens, I will also check out the spring there as well.
