1 - 11 of 11 Posts
It's about time to replace my air filter on my 02 Sportster 883 Hugger and I'm considering replacing the stock one with a K&N filter equivalent. Would you recommend the K&N filter?
The prices I've found online are in the $55-$65 range. What is a good price and where is a good place to buy online?
I'm not looking for the high flow filter but rather one equal to the stock filter. Will this still require me to rejet the carb?
Thanks in advance for your help.
If you use the K&N filter, you will probably need to rejet the carb. The OEM filter is very restrictive thanks to the good folks at the EPA.
If you just use a K&N in the stock air box with stock mufflers your OK. For 65 bucks or less you can get the real deal in the S/E air cleaner. After all its a K&N filter anyway, but with a less restriction because it realy has no "air box".
Help - Problem with air filter?
Well, I received the K&N air filter today (part #HD-1388). When I replaced the stock air filter with the K&N I noticed that the K&N is slightly wider than the stock one(about 2-3 mm). Because of this when I put the cover back on there is a slight gap between the cover and the backplate. Is this a problem and if so what can I do about it to make the air filter fit right?
Thanks for your suggestions.
Back up there. Did you say you got a S/E air cleaner or just the filter? The S/E air cleaner has it own backing plate thats flat. The space around the cover and the backing plate is where the air is drawn in from. Whats up?
Discussion Starter · #7 ·
I bought the K&N brand air filter element not the SE. I have the stock backing plate.
The goal was to simply switch the stock air filter with the K&N without having to rejet the carb.
1 - 11 of 11 Posts
