1 - 11 of 11 Posts
I just got a 95 kit on ebay---all new stuff. The screamin eagle pistons are #22114-99a. Has anyone got any info on these pistons. I can't find anything on the net about them. I would like to know the comperssion ratio. I am putting them in a 99 ultra.
22114-99a is not a correct part number.
Most likely flat top pistons, I believe will give a CR of 9.3 to 1
using harley head gaskets.
'04 FXSTDI
That is the same part number that is on my pistons that have been sitting in a box for the last 3 years. Basic 95 inch BB kit.
22114-99a is the pistons that come with the 22851-99A standard bore kit (which includes pistons, rings, pins and clips). Advertised compression ratio with stock heads is 9.4.
'04 FXSTDI
By standard bore you mean 88inch?
I get it now. I just came across these last night. After scraping off the stuff built up on the top I saw the 22114 # and was a bit confused. The rings, clips, and the actual pistons as a package make up the 228.. part number. Thanks.
1 - 11 of 11 Posts
