I thought about that because I changed out the switch covers a few years back. May have pinched a wire on the kill switch and its failing now. I will pull that apart and see. I just might replace the switch all together. thank you.System relay is operated by the on-off handlebar switch and the e c m, it controls the power 2 the coils , fuel injectors and fuel pump, so if it's dying and the fuel pump is not running, I'd start there.
Thanks for the advise. I will check on these things this weekend and get back to you all.It is cranking over, but fuel pump not coming on. Get on wiring schematic, that might tell you something. Or the flow chart.
I would think if the wire were pinched it would blow fuses,, maybe bad switch or relay, I would start circuit tests.I thought about that because I changed out the switch covers a few years back. May have pinched a wire on the kill switch and its failing now. I will pull that apart and see. I just might replace the switch all together. thank you.
I'll start there. Thanks.I would think if the wire were pinched it would blow fuses,, maybe bad switch or relay, I would start circuit tests.
Replace the main circuit breaker with a size larger. There was a recall for this on the early 88s. Had to do it to my 2000 ultra in 2002. Never had another problem.I have an 05 Ultra Classic with the 88ci. I'll be riding and out of the blue she will die like I turned off the ignition or hit the kill switch. After I get off the side of the road she will not start. When I do try to start her she just wears down the battery like I have the ignition switch turned off. When I turn off then on the ignition switch I can't even hear the fuel pump prime. I have sat there for a couple of hours and then I can get her to start. A couple of times I have towed her home and she wouldn't start for a week then all the sudden she comes to life. I have gone through all of my connections cleaning and using dielectric grease. It is so random when it happens. Got me scratching my head and drinking a lot of whiskey. Help is needed. Thanks in advance.
Seems like if there was a recall on this that you used in 2002, it would have been fixed on new bikes after that. But maybe not.Replace the main circuit breaker with a size larger. There was a recall for this on the early 88s. Had to do it to my 2000 ultra in 2002.....
They did put bigger breaker in, and then went to fuse.Replace the main circuit breaker with a size larger. There was a recall for this on the early 88s. Had to do it to my 2000 ultra in 2002. Never had another problem.
bike cranks over.Just a thought....have you looked at/into the Tip over/Bank angle sensor?
Ok, so I have an '03 that does the same thing. If you give it 15 to 20 minutes it should start again. The power relay gets hot and thinks your drawing to much current and opens. There have been back in the early 2000's a bunch of threads on this with fixes, I find it generally happens on hot days that I'm not going fast enough to keep the heat down. Hope this helps.I have an 05 Ultra Classic with the 88ci. I'll be riding and out of the blue she will die like I turned off the ignition or hit the kill switch. After I get off the side of the road she will not start. When I do try to start her she just wears down the battery like I have the ignition switch turned off. When I turn off then on the ignition switch I can't even hear the fuel pump prime. I have sat there for a couple of hours and then I can get her to start. A couple of times I have towed her home and she wouldn't start for a week then all the sudden she comes to life. I have gone through all of my connections cleaning and using dielectric grease. It is so random when it happens. Got me scratching my head and drinking a lot of whiskey. Help is needed. Thanks in advance.
