So if you are just going to run slip on mufflers w/baffles along with the
HD high flow air cleaner, is the Stage 1 download all you need?
The Bike:
05 FLSTSCI
Samson Silver Bullet Fishtail Mufflers w/baffles
HD High Flow A/C
Stage 1 Download
The bike runs great,very smooth and good throttle responce.
I do not plan any other future mods as far as performance.
The Bike:
05 FLSTSCI
HD High Flow A/C
Stage 1 Download
It will help, but dyno tuning is the only way to get it right. Otherwise you won't be getting the most out of your engine. Before that, try to get a K&N air filter if you don't have one already. They flow more air than any other type.
But it runs better than stock, and much better than it did with the True Duals and a PC.
The bottom end is much better with the stock head pipes and no popping on decel.
I am having second thoughts about putting the PC back on because the bike seems
to run better than ever and is getting great milage. And no I never had the bike
dyno tuned before...I had been running a map that PC recomended.
Ok, I ordered the DFO just now, I hope I like it better than the PC.
It was alot cheaper, found it on ebay for $165 shipped...
Thanks Again
Barry
