Yup, I used to live in the Porsche world, I have stolen a LOT of ideas from them!Dimples are revolutionary on a Porsche. All of the Porsche guys have them.![]()
Thermo-Back there in my memory one of the Big Bloch Fords used a 35 Deg intake, I never understood the reason.
It might have been the 427 or 429 ...not the "f" heads.
Yes, raising ports is always a good thing.
OK you are talking about seat face angles. When talking about raised ports and angles, the angle is referencing the valve stem. By leaning them back at the port, you can improve flow. In that photo of the 292 Chevy casting you'll notice that the intake guides have been replaced, that's because they were tilted an additional 4 degrees. That was about as far as you could go on them and not develop cracks between the seats with 2.06/1.60 valves. They also were getting pretty thin in valve spring seat.A quote from Joe Mondello.
Here, he gives a LOT away!
Lots can be learned from others if we painstakingly read slowly and add all the parts together from different places.
start
“A few weeks ago, we had three engineers from Harley-Davidson Screaming Eagle Division here for a technical session. They just designed a new 103 head and a 110 head and were quite proud of how well it flowed. We took their head, and in three days time we improved the airflow 52 cfm over their initial design. Out of the 53 cfm that we picked up, 25 cfm was due to changes we made in the valve -seat _angles +alone. That shows you how critical valve seat angles are for maximizing airflow and power,” says Mondello.
“Many cylinder head manufacturers are using single point cutters on a CNC machine to cut their valve seats, and they are not spending much time blending the chambers or doing all the things they really should be doing to make the valve job work properly. That’s actually good for our business because we rework a lot of these cylinder heads, especially Harley heads,” Mondello explains.
end.
Thermo-
I Found it!
Very few valves outside the diesel market have 30-degree seats, but one notable exception is the Boss 429 valve, right. This Manley Boss valve measures 2.280-inch with a 30-degree seat measuring .100-inch wide. There’s also a .060-inch margin
Valve Seats: Will 50- or 55-degree Angles Work For Your Engine?
Very few race engines run a 45-degree valve seat anymore, but that doesn't mean a 50- or 55-degree seat works on the street.www.enginelabs.com
Dimples might help if you have a golf ball in the intake port but I'd just remove the golf ball.
The old school trick with Shovelheads was to weld the chambers up so they looked kind of like Evo heads. And then run pistons that only had about a 3/16 dome on them. Made for better flame propagation and gave you some quench to help with detonation.PS
Once we tried moving the guides on a shovel so as to get more lift without interference.
The nuances of valve angles per application is the quandary to deal with.
Then EVO came along....lost interest ( in the shovel )
Ya, no internet. So you had to read and actually hang out with people who knew. There were no experts banging on keyboards in gandma's basesment back then.Sounds correct to me-
Back in the "day", there was no internet for instant information such as now ..better, and sometimes worse.
We were left on our own until the next issue of your favorite rag came out on a monthly saga.
Sometimes there was something helpful in there with Bob Bitchen or some traveling nomadic author of not much.
I hardly knew a quench from an inch!
but, we all preserver through the University of Hard Knocks.
Win some lose some.
No I use Pipemax and Flowpro software and pito probesDo you all use the math for flow density as apart of your porting?
