don,
You come across like I have incinerated you
insulated you.
Up to this point I have not.
As i said B4 you should maybe perhaps say "Congrats man, a job well done!"
As I said
I build for a TBO for a hopeful 20K .
So far I have only failed once because more schooling was needed on
the ramifications of the pinion nut and some not-so-stock valve springs.
As far as investing in a store-bought wind tunnel,.... i have outdone many who have one , so what the point in dising me for my farmyard ways of doing things/?
You do Seems caustic.
PLUS-
There is nothing wrong with all that you found fault with in your above rants, some of it will not add any power, some will, none would hurt anything except the wallet.
Ceramic bearings are tomorrow's technology today.
Get used to them, I suggest.
I will guarantee you- port styles will be forever changing for the next forever as long as we use them
Don't get caught in your latitudes, bad attitudes, laurels ,and dissing someone cause it WORKS.
Bigger name shops than yours advocate dimples now.!
And -
No, - Nasty car will not permit them, they are too hard to hide from the judges.
So don't get caught teaching history lessons as you will be left behind on the grid.
By your own admission, you have not created a low RPM 1.25 engine
I have!
Why kick dirt in my direction of success?
i get the idea you are sort of a bitter person?
It runs to Sturgis and lots of other places quite nicely, and I like it for my ego, I will admit it.
Harley engines- are not my forte, Nor even a sideshow, i do lots of other stuff, not my wheelhouse or for a living. Even.
You should be able to add fragrance and flavor here, a demeanor of professionalism, not indifference.
This makes you look very insecure.
If you want to brag about being anywhere as you did above in the little sermon and rant, I have been on the planet for 70 years and am still learning as i go.
I don't think you have peeked yet?
I certainly hope not.
I hope the best for you!
Smoky is still worth reading.
I would be open to his critique ..he had a way about him.
He also won races.
If you want to dis and shet on someone, you need more on yopur resume then a "I own a wind______ table ."
Results in the real world is what counts .
I am open to your apology. (if you can muster it)
