1 - 2 of 2 Posts
You guys using loctite on your intake maifold bolts?
I am trying to get the bolts out of my evo intake (stock) so that I can install a 1 piece RamJett and do away with compliance fitting. Man I have about stripped the ball end allen trying to get those pigs out of there. I may end up having to remove the tank!
Any suggestions?
Try heating them locally with a heat gun and then a little Kroil to help break down and relieve the tension of the original locking agent. Object is to remove them hot. Might have to cut down an allen wrench to a convienient size for access so you can get some a$$ on the wrench to turn them out also...Good Luck.
DLR
1 - 2 of 2 Posts
