Installing V&H Quiet Baffles
has become nothing but a big nightmare.
Before thinking about switching over to them.
First look at the comments from V&H. The quiet baffles were only done as a response to folks requesting something more quiet than the stock baffles. Ie. they really don't want to make them but feel they had to. That should be your first clue. There is little or no support if you buy them.
If you decide to go with them (and I suggest you don't), make sure you tape the entire area where the fiberglass is completely covered with tape, not just the two little pieces they supply or else the baffle fiberglass will get jammed up in the exhaust and will not do what they are designed to do. Not only that, but you will never be able to get them out without destroying either the baffles or worse yet, the entire exhaust system (which I did). If that is not enough, just know even if you do get them installed correctly, they only take down about 2 to 3 db's which is nothing in the db world.
I am now working with the possibility of using the Hard Kore Quiet Baffles. We'll see.
