inspec. sticker plate
760 Views 8 Replies 9 Participants Last post by  DM-SC
Where do you mount those plates you can get for your inspection sticker?
1 - 9 of 9 Posts
i have mine mounted to the frame under the left side passenger floorboard...a friend has his mounted to the left lower crash bar bolt...but he can't put his lower fairings on.
some places won't put the sticker on them unless there's a pop rivet thru the plate & frame too.
I have my DOD sticker plate in the same spot. I run soft lowers so it's not a problem.
The actual required location is" forward left 1/4 of bike...I've seen them legally installed on the forks, left peg mount, left down tube of frame, (mine on a plate attached with a highway peg clamp) and some stuck to the down tubes on forks, the rest are all over the place but lacking any place better I don't know how they could enforce the location requirement.
Look here, and down the page: http://www.motoleather.com/moac--motorcycle-license-plate-frames.html
or here: http://www.ipass.net/wb4iuy/scootr2.html
I have my bridge sticker stuck to rubber magnetic material(3"x4"), and I just slap it on the electrical cover to get through the toll booth, then it goes back into my back pocket.
Thorns
I installed mine inside my saddlebag....
:brows:
Mine is installed on the left highway peg. Don't exactly think it looks great, but ya don't have a lot of options if you wanna be legal
Mine is behind the rear passenger peg between the upper and lower belt guard.
I have a flat plate that bolts to the cross brace between the down tubes...
1 - 9 of 9 Posts
