Can anyone out there give me some tips on installing these on my 01 Deuce?
Do they go on the outside or inside of the frame?
Do you hang the top bolt on first and tighten and then the bottoms?
How do you get the bottom holes to line up? I've tried the jack but all I get done is bend the top bolt.
Do I need to shim the top bolt? When I did get them on my brake pedal when fully depressed hit the bar a litte.
If I have to loosen the forward controls. What did use to loosen the loctite and not damage the paint and chrome?
You can see I'm having a great time putting them on.
are you sure you have the correct model Lindby for a Duece? I mounted these on my Fatboy in less than 5 minutes...no problems at all. All holes lined up and I have an extended brake pedal that doesn't interfere at all.
