I'm dizzy from searching the archives about 95" builds. I'm trying to balance gaining additional power with a budget. I'd like to keep the cost under $1800.
I have a 2002 Road King Classic (FLHRCI).
SE Air Cleaner
Rinehart true duals
PCIIIr
I want to keep the Rineharts because to me, they sound perfect and look better than anything else out there. Plus I already have a $650 investment in them.
I'm pretty sure I'm going to ebay the PCIIIr and get a SERT. Mainly because if I keep the PCIIIr, I'll have to pay to have the Stage 1 flash done and there are more shops around Atlanta that can dyno a bike with a SERT than a PC.
I'd like to keep the compression under 10:1. I'd like to get close to 100HP/100TQ numbers. I know the Rineharts will result in lower numbers.
So, I'm looking for members out there who have done a 95" build and are using Rineharts. Anyone?
Lastly, can someone reply with a checklist of items I need to buy. It would be very helpful and IMO, would be worthly of a STICKY if someone would compile a 95" Build 101t post. Run through the different gaskets, bearings, cams, exhaust, etc. benefits. Might save a lot of newbie posts.
I know I need the following:
Pistons
Cylinders
Cams
Gaskets
Heads (will send to someone for porting)
Bearings (torrington?)
Baisley Spring (what the hell is that and do I need it)
I'm an extremely compentent mechanic but I've never been inside an HD motor. I bought most of the cams tools but I still need to buy the inside cam bearing removal tool. I'll take the cam plate to the local HD dealer and have them press out the old cams and press in the new ones.
Thanks,
Michael
Roswell, GA
SE Air Cleaner
Rinehart true duals
PCIIIr
Pistons
Cylinders
Cams
Gaskets
Thanks,
Michael
Roswell, GA
