LDO Mastiff said:
Ok,
help me out here. I'm looking for a see-thru inline fuel filter that won't take up alot of room. Any recommendations?
thanks,
LDO
Yes, don't use a in-line filter.
Assuming you have a carb and standard fuel tank, an in-line filter typically sits between the cylinders and heats up and can cause vapor lock. Check and clean you in tank petcock screen.
Just my opinion, based on having to troubleshoot this on my bike many years ago. I could go 60 all day long but at 65 it would run the bowl dry. If you stopped to check it out, it would flow enough to fill the bowl before you could check it. Fuel filter vapor lock was the issue.
