So I installed a Dyna 2ki ignition on my S&S 107 when I put it in my FXR. Ran great. Rode to my indie's Friday morning to show him my project. When I got home, I pulled the cover and upped the rev limiter to 6500 and bumped the timing to the highest advance. Fired it up (engine still warm) to make sure it would start and all was fine. So I starting prepping for company coming for the weekend.
Saturday morning, I go out to fire it up and all I get is spinning over. I figured it was a timing issue, so I pulled the cover and set it to the original setting. Still no go. I contributed it to being flooded and went back to the visitors. Tried a couple times all day with the same results.
Yesterday I pulled the plugs and they had gas smell. Cleaned and was fixing to reinstall when I figured I'd check for spark. That's when I found I have none.
The Dyna module LED flashes once when you turn on the ignition. It flashes pulses when you crank the motor. I have 12.4 vdc at the coil (battery's a little low from cranking). I get pulses at the coil from the module, but my digital meter can measure the voltage.
I checked resistance on the coil. 2.4-2.5 on the primary. 10.8k on the secondary. Kind of low, so I went to my indie and picked up a spare used one he had. It had 2.3-2.4 on the primary and 10.6k on the secondary. Needless to say, still no spark.
The plug wires had 5.0k on the front and 5.5k on the rear. So they're good.
So is there another test I can do, or do I just need to order another coil?
Sent from my 2 Tin Cans With A String using Tapatalk
