replaced grips and now adjusting idle throttle cable, service manual shows cable housing hitting spring but can't see spring, all enclosed. how do you know when it is adjusted properly then, any info would be appreciated. i adjusted cable by turning wheel to the right and return of throttle was slow, then backed up a little bit. now a week later and throttle doesn't want to return by itself. throttle lock is loose too.
