1 - 19 of 19 Posts
Infidel
I *think* HD came out with a version of the race tuner for Magnetti Marelli EFI bikes. This tool would allow you to adjust you idle.
There is an idle adjust on the Marellis, behind the cleaner. Best to have the manual,it shows location, and then describes how to reset the ECU after adjustment.
The delphi is adjusted electronically, it is on one model for 2001--forget which model. It is not the Glides or Road Kings
What are you idleing at now? Two potential issues 1) The charging system likes about 1K rpm to not drain down the battery and 2) The oil pressure drops signifigantly with RPM. Suggest you keep the stock 1K. If uou can't find a manual, I could scan the picture and instuctions.....highly suggets teh maunual however. Many uses
Infidel
McClendons,
Thanks for clarifying the issue. :yes:
regards,
wyo
Your bike has hot and cold idle adjustment screws, and there is a separate procedure for each. If your bike is idling where it should be (950 to 1050 rpm's), the best thing to do is leave it alone.
Ragnar
Discussion Starter · #7 ·
This is for my Heritage .... I am idleing at about 1150 right now... would like to lower it to about 950.... I would like to see the instructions.
Get a service manual.:duh?:
Here's what you do:
- Ride it till up to operating temp.
- Take off the aircleaner cover and element.
- On the backing plate you will see a hole. Stick a #10 Torx in the hole and turn the set screw counterclockwise to decrease the idle.
- When you get to the desired idle, shut off the engine and pull the ECM fuse for 15 minutes.
- Put element and cover back on and recheck idle speed.
In '01 the touring bikes were still MM, but I believe the softails had already switched to Delphi. If this is the case, and I think it is, your bike has the Delphi EFI, and the idle is not adjustable, except by a dealer.
Ragnar
Ragnar
You are correct, my friend.
Ragnar
Give the man a ceegar.
Ragnar
I have to agree with above statement. I wanted my 01 FI deuce to idle at 900, which would give it a little better loping sound. Harley dealer was against it. Charging was one reason forgot the other but I just left it alone. Mine idles from 1000 to 1050. Live with it !!!!
1 - 19 of 19 Posts
