1 - 10 of 10 Posts
'05 FXST, installing the SE ignition module. Procedure for setting the ICM password involves cycling the ign. switch every 10 minutes. I'm not having any success after completing the steps.
One thing that is not happening as I perform this procedure is though the engine starts and stalls (as per instructions) I'm not throwing a code, nor am I getting the check engine lamp 4 seconds on, 4 seconds off, 8 seconds on, off sequence. In fact, after the 1st 10 minute cycle, the check engine lamp goes out just like normal. (Here is where the SM differs from the instructions, SM doesn't mention anything about the check engine light). Hope this is enough information so somebody can help?
THe learn process can be a pain without the Digital tech, I have treid to do it without and some times it works and other it would not. Make sure you follow the directions as stated, and if you are and it is not working you will have to take it to a dealer and have them do it.
I just purchased a SE ICM for my sportster...is this what I have to look forward to when it arrives? I haven't read up on ICM installation procedures yet. Can someone enlighten me? Thanks!
Discussion Starter · #6 ·
I tried it again last night following the service manual to the letter. Still didn't work, and the fact that she doesn't even throw a code like the SE instructions say to expect tells me its just not going to happen. I guess at this point I'd like to just know why the SM makes password learning look pretty standard and if its actually not applicable to my bike then what else in that manual is not accurate? (already know about the torque specs).
Can't speak for your experience with the sportster, but I say give it a try for sure. If you have a TSSM it could come out totally different. If it fails, plugging back in the stock ICM is all you have to do to get her to start so you have nothing to lose trying.
What's a TSSM? All I have is the factory service manual.
Hopefully all will go well. Good luck to us both!
Discussion Starter · #8 ·
Thanks Homarr!
You either have a TSM - turn signal module, or a turn signal security module. If you don't have a key fob then you don't have the TSSM. The TSM I believe is what cancels your turn signals, controls the flash rate depending on load, and shuts off your bike in the event you are leaning over 45 degrees for more than one second (i.e., dropped it while running).
Doh
OK, now I see. No, I don't have a TSSM. Hehe, I thought maybe TSSM was some other manual, like the elctric diagnostic manual or something. Thanks for the info.
1 - 10 of 10 Posts
