'04 Dyna Superglide. I need a new map for the heads & cams I just installed.
Here it is:
95" w/SE A/C & slip ons
SE performance heads, flat pistons
SE 211 cams
Can I use one of the canned SERT maps for the 203, or 257 cams w/ perf heads ?
I can't see paying several hundred at this time for a full-on dyno session.
Thanks in advance.
Here it is:
SE 211 cams
Thanks in advance.
Since the SERT doesn't include a specific map for your configuration, and you don't want to spend for a dyno session, I would suggest inquiring here:
www.hdmaps.com
:cheers:
Unfortunately, I didn't see a map in there either.
