@gree: exhaust leakIt looks like exhaust stain to me. Is there any way you could have a leak directing exhaust toward that area?
Yeah. I can feel puffing from that area. So, it's definitely exhaust.It is possible that you have an exhaust leak in your rear cylinder (exhaust gasket). When its running, put your hand in that area and see if you can feel any puffing...
rkc
This bike hasn't been doing any sitting (aside from the time it's spent in the shop).do you have a Battery Tender, if the bike does any sitting you should get one,
Ya. I've given the kick start a try. I wasn't anywhere near successful. But, I'll give it a shot another time when nobody's looking. lol."the starter button has been tempermental"
That arm with a pedal on the other side is called a "kicker"It doesn't take much battery to fire her up. Wish my 82 had one.
@gree: They will vibrate off if left loose too long. If one of the flange nuts is missing just replace it along with a flat washer and tighten. Your leak should stop.Just try to tighten the flange nuts and see if the leak stops.
It wouldnt. I may be "off base" here but, from the pic's it looks like only the solenoid and a small area around it are "blued", that takes allot of heat in that immediate area. You also mentioned your having problems with the cheater button so, I'm wondering if the solenoid got hot at one point. This could be caused by a short, (intermittent), or it's just old and wore out or, the starter dragging. Since the exhaust is on the other side, it's ruled out and, it couldnt be the upper jug gasket since it's above the solenoid and not close enough to cause it. And, if the gasket between the case and bottom of the jug were leaking, you'de see oil, not exhaust gasses. If you still think it's exhaust, put the bike in the garage or somewhere where theres absolutely no wind or air current's, fire it up then take a lit cigarette or, even better, a cigar, and hold it next to the solenoid and watch the smoke. If there is a leak close to the solenoid it will blow the smoke AWAY from it. Move the cig around till ya find the leak.Wait, I'm confused.
How would a loose bolt on the exhaust on the right side of the bike, be causing exhaust to be puffing on the left side of the bike
