Well Guys I'M DONE FOR ~ +SMSH+
After taken all the body parts off the bike myself and having the bike custom painted. After locating and buying missing screws/bolts/etc,etc. Going back and forward to HomeDepot/Lowes
and all the rest ~ I'M DONE !!!
Its true I haven't started the bike in about four (4) yrs. do to a little thing called CANCER of the kidney and some other parts they took out. I've recovered well SO-FAR.
Now here's what happened:
In the back of my mind I'm wondering if the PISTONS ARE CEASED after all this time of not starting her-up.
I would check on the bike on our back patio and notice an oil leak from under the bike. Not having the strength to do anything about it; I let it lay.
Little do I know at the time the OIL was leaking from a oil breather I had installed many,many years ago and for what reason I cant remember. Lets not forget I bought the my Electra Glide Classic brand new in 1985.
O.k. I'm ready to have the bike re-painted. Still wondering if the bike is going to start.
The bike had no oil due to the constant leaking thru the years coming from that DARN OIL BREATHER. I put new oil and oil filter on the bike.
How I tested if the pistons would turn I did this:
Got a wire coat hanger and straighten it out and made it to come out of the spart plug hole about 3ins. I put tape right at the beginning of the hole where the wire hanger rested.So I could tell if the rear piston moved up and down. I jack-up the rear wheel and put the bike in gear and hit the starter. And LOW AND BEHOLD THE WIRE MOVED UP - INDICATION THE REAR PISTON
IS NOT CEASED. I didn't test for the front piston figuring if the rear one move I'd be O.K. ~ and GOD said, " YEAH RIGHT
Now I thought I was home free ~ WRONG
I put the spark plugs back and pumped the throttle a bit and I hit the starter.
Well the engine made the rrrrr sound and then came THE KNOCKING
AND the knocking. Not being a motorcycle mechanic I know I was in trouble.
Little did I know as I was trying to start her up; My wife yelled out to my from the livingroom; " Honey there's OIL COMING OUT OF THE BIKE "
I stopped hiting the starter and look-over the right side of the bike on the patio floor was: LOOK AT THE PHOTOS.
I need your imput guys; I know its bad but I don't know how bad.The start works, got a brand new battery in there, new oil and filter like I said.
Really Dumb Question To Ask: What is causing that KNOCKING.
Remember the rear pistons did go up and down. Why wouldn't the front piston move ALSO
After ALL that work !
I'M DONE, FINISHED & DEPRESSED !!!
O.K. guys I'm in your hands tell me what you think ?
