hi
my build .... 04 flhtc woods tw5g non cnc htcc 182 compression both cyls hot or cold difference is about 2 psi .
feuling oil pump crane roller rockers and adj push rods
stock cv carb except for yost power tube .
using manual compression releases the bike kicks back worse when hot sometimes have to crank it over 3 or 4 times before it will fire up .
using a dyna ign module set at 28B as suggested by the dyna tech dept .
Battery seems charged up ok , is there was some way to shut the lights off till it fired up to give the battery a bit more power .
this is still the origional battery from 04
You can put a switch of some kind on the headlight power. It is a good idea, but is illegal in many states and is required on all motorcycles made to be used on the highway in the US. I imagine that there is a similar law in Canada, they like daytime lights. I would use a switch that lights, so that you know that your lights are on or off.
decker said:
hi
First are you using stock lifters, they can bleed down and give you the problems you described.
Second Original battery could be weak have it tested with a load type tester. Third you can replace your battery cables with some upgraded cables(they make a difference).
Fourth sometimes starters get weaker when you put heat on them. can you heat up the starter with a commercial heat gun when the rest of the bike is cold.
Last when you have a hard time starting you can drop the battery voltage down to where the ignition does not want to work well. Crane sells a relay that allows more voltage to the ignition when you are cranking, this can help a lot.
If you have any questions please feel free to contact me.
John Therrien
M.I.A. Cycles,NY
thanks for the reply ..yes I am using new stock lifters one thing I did notice was the rear plug was black when I pulled it out and the front a normal light brown also my muffler was black instead of its usual grey colour [I would have thought going from 1450 to 1550 and the htcc heads and cam I would be running lean not rich ]going to check my slow speed jet see whats in there and the needle position I havent opened it up enough to get to the main jet yet trying to keep it under 3 grand for a while I forgot to mention I am running a 2 into 1 bassani road rage .
