Hello all,
I have a 2000 Dyna with a big bore kit and a Baker six speed. I recently upgraded the bike with HTCC Heads, Pistons, Manifold, CV 44mm Carb, SE 257 cams, and the SE Programmable ignition module.
My problem is I have what sounds like a rod knock and or piston slap on Deceleration(sp?). The bike has been in the shop three times for this noise. I prior visits they have replaced the primary chain & gear(s), oil pump, cam bearings & gear(s), cam chain tensioner. This last time they pulled the motor split the cases, and spec'ed out the total bottom end of the motor. Everything is within tolerances, they have told me, and I quote" ride it 'till it breaks and we'll fix it", this does not give me warm fuzzies.
I am basically on my legs, the bike has been down for three months, I went with a Harley dealership using all harley parts, spending good money and I still have issues.
Has anybody run into this??
Can anybody point me to a person or info that may be able to help???
Thanks in advance,
Dyna boy...
Thanks in advance,
Dyna boy...
