You didn’t mention what year model, but the 1999 88” model (Magneti-Marelli EFI system) throttle position sensor adjustment is well outlined and best followed as per the service manual. I’m sure the same is documented for later model HD service manuals as well. Note that the procedure requires an accurate milli-volt to volt-range range voltmeter and recommended ECU breakout box interface. I believe there is also mention of an ohm meter check for the temperature sensor. However, if there was anything seriously out of order with either of these sensors that you’d probably be seeing frequent service code warnings. If you were to attempt altering the original throttle position sensor setting you’ll likely affect the A/F control settings in the low throttle positions, perhaps favorably or unfavorably. The idle on many EFI HD’s tends to drift a hundred RPM or more in various temperature, humidity and altitude environments. Yours just might need a simple idle set screw adjustment to ensure worst case hot engine idle is no less than 950RPM.
