Springer,
Do you have a similar post that shows how to file the rings during installation of new piston and rings?
Use a ring end gapping tool. It's small hand operated grinding tool. Or if you only have to do it once, you can use a small fine file. Always remember to remove any burs left by which ever tool you choose. The operation is self explanatory but if you need a post on it, I'll make one. I am sure your service manual shows you how to measure the gap.DNLEVESQUE said:Springer,
To obtain .030"-.035" of squish using the stock .045" heads gasket, the piston needs to exceed the top of the cylinder by .010"+ The tightened squish area makes for a more efficient combustion chamber. Bean had previously adjusted the original cylinders to the proper deck height. With the new cylinders, the customer didn't want to lose any performance so we had to match the original deck height.hdmarsh77 said:How do you know how high to make the pistons above the cylinder? Was this one just a case of making it the same as it was? Also, what would happen if you had left the pistons lower?
Great info Springer!
springer- said:To obtain .030"-.035" of squish using the stock .045" heads gasket, the piston needs to exceed the top of the cylinder by .010"+ The tightened squish area makes for a more efficient combustion chamber.
The same principle can be applied to the Twin Cam. In the Twin Cam you can bring the deck height to .000" and use a cometic .030" head gasket to obtain a desired quench. You could also set the deck height at +.010 and run a stock head gasket and obtain a .035" quench.
QUOTE]
Springer sorry so late on this post, but on the TC you said the deck height of .000 to get a .035 quench. Would you mill the bottom like the EVO or can you turn it from the top of the cylinder sence there is no gasket at the bottom of the TC?
Get post by the way, as always :thumbsup:
