Hi!
I'm would change the handlebar on my RK Custom
But when I removed the fork lock plate I found two bolt without head!
I can remove only using a drill!!
Anyone could help me?
Nicola
p.s.
I live in Italy so I have an International version.
G
For some reason, the HDI (International) bikes have these screws. The only way I've heard of removing them is either to drill them, or use a chisel to punch a slot in them, then use a screwdriver.
Harris
You'll have to remove the wind deflector. Take the headlight rim loose, remove the headlight and there should be some screws on the inside of the nacelle. Remove those and lift the deflector off. That should expose the handlebar clamp and bolts.
NOT what he said... he must not have looked at your picture. Yes, what the first reply said. You'll have to drill them out or something. USA bikes have countersunk phillips head screws that go in those two places, never seen an HDI setup before, that's weird.
