How many miles do you get on front d402 tire
1981 Views 10 Replies 11 Participants Last post by  NHMongo
I have 12,800 miles on my bike and am getting a new rear tire on my road king.Question is should i change the front now also.How many miles did you guys get on your stock front 402.Should i change it now.:wacko:
Thanks Pete
1 - 11 of 11 Posts
personally I have alway felt if you replace one, replace them both. The threads many not look wore but they are. and what's another $100 or so for safety and ride stability.
Well I always do a 2 to 1 ratio on rear to front, but I replace my rear every 8k miles, so that is just 16k on the front.
Inspect the tread, if it looks worn unevenly replace it. If it cupped replace it. If it is cracked replace it. If it below 2/32 tread thinckness replace it.
I got 39k out of the original one on my RKC. The odometer is now at 57k and the second one still looks good.
Most everyone I know with a touring bike gets between 30-40K on the front tire. Don't see any need to change it when the back is changed.
25-30K for the front.. 17-18K for the rear ... on my Fatboy...
For me it a 3 for 2 swap, three rears for every two fronts. Since I just built my motor, i expect rear tire wear to be greatly reduced!
This is my experience as well. :yes:
2 to 1 ratio also with 8-10k on the rear. When I change the rear the 2nd time the front automatically gets changed.
Tire change rate
22,000+ on 05 Ultra - original front tire still great. 13,400 on first rear tire change out. I wouldn't base decision soley on mileage - wear should be the driver. But if you are getting the same mileage on the front as you get on the back I would have some concerns over quality of the tire. Tire pressure and riding style play a lot in the wear rate.
Scott LaShier
Stafford, VA
Same here although I got around 10K Rear and 20K front before I changed to ME880s. Jury is still out on how long those last. 5K and they still look good. If I can get anothe 5K out of the rear I'll be extremely happy. They are a superior handling bad weather/road tire than the Dunlops.
1 - 11 of 11 Posts
