my 2014 103 dyna revs at start when I start then drops just started this after dead battery code b2771
Make me use my bullet?
This is not news.
I don't think there is a b2771 DTC, nor do I think there is a DTC for a dead battery. Where did you read this code? Did it go away after you jumped the battery?
"b" codes are for the BCM. Maybe you had a b2271 which would be for BCM voltage low?
If you were jumping then I'm guessing the bike sat for a while. Does the idle drop back to normal? How long does it take to drop? How high does it "rev"?
Try cleaning out the IAC module. You could have a failing engine temp sensor. Are you twisting the throttle when you start the engine?
You can go here to introduce yourself so we can see you're not just another troll or trying to bash on somebody or sell us something. My Story, the Beginning...
You're posting into a forum for news. Go to the correct technical forums to post questions. Twin-Cam Engine
Try typing real sentences and giving a little more information about your problem. We aren't there, we don't know the backstory, we can't see or hear your bike.
Thread is in the Twin Cam section now.
If your battery is good now and the charging system is charging then I would ride it for a while.Chances are the idle problem will correct itself.They should idle up some when first started.
