2001 1450cc TC 88 with Stage 1 pipes, A/C, and jetting job, 20,000 miles. after i run for a while at highway speeds and come to a stop, the idle is high. if i let it sit for a while and restart. idle is ok. doesn't happen around town on short trips. heat related? any ideas as to where to start troubleshooting?
check intake seals with a spray bottle of brake cleaner. If rpm changes, do a gasket job. There are other causes, but I would check that first
Not-so-Fatboy
That's what I would have said. Had the same problem on my '05 Fatboy. Had a similar problem afterwards, but realized that the idle was set when the bike was cold vice warm. That made a huge difference......
What would you check if this checks out?
I have the very same issue.....
K.
Manifold gaskets and rubber doughnut between the carb and manifold.
And as mentioned above, do the final setting on idle after the engine is good and hot, 15-20 mile ride.
