I installed a PCIII USB on my Street Glide today. I had been getting significant decel popping since after getting the Stage-1 kit and SE pipes. I purchased the PC to address the decel popping and to get as much performance as I can from my present set-up. This Afternoon I rode around for about an hour. The decel popping and the occasional backfiring is gone so at least the PC did it's job there. Also the engine seems to run a lot smoother at idle and at very slow speeds like when slowly coming to a stop. There is one concern though. Normally my bike starts instantly when I press the starter switch. With the PC there is a hesitation of about 3 seconds before the engine kicks over. It does that every time I start the bike now. Is that normal with a PC? If not is there a way to adjust it so it will start normally? The map I'm using is from the CD that came with the PC. It's for the exact same set-up that I have with the exception that the map is for a 2002 bike and mine is a 2006. Thanks.
eddie
eddie
