I have a 2000 deuce S&E 1550 bb stage 2 with 203 cams, high comp. cast pistons, stock heads,S&E 6200 ignition, stock carb. Can any of you fine members tell me what woods cams i can use with this build? Thanks Guys
Doc got it!! The tw6 will bolt right in. You will see larger increases with the tw5, but you will need to increase your spring pack height to accomadate the higher lift. So if you decide to go with the higher lift you may as well consider some basic headwork to really allow the bike to breath, otherwise you will see small gains over the set up you have now.
Happy Sunday!!
