2005 Dyna lowrider. I want to put on some detachable bags with easy brackets or ghost brackets. I need to relocate the turnsignals. J&P cycles has a relocation kit for Dynas up to 2001 for $30. No Kit for 2002 up. The HD kit for 2003-3005 Dyna is $70+. Did HD change the bolt size for the rear turns signals in 2002? I am guessing this is the case as HD also has 2 kit for pre and post 2002. If not then I see no reason why the J&P kit would not work. Both kit are basically a bar that use the Lisence Plate bracket to mount it and the turn signals are mounted to the end of the bar. I just don't want to spend extra $ for a HD bar. Pissis me off the HD would change a bolt pattern for no reason but to cash in. Spending enough on the brackets and bags. Your help is greatly appreciated.
