DRIMNER1 said:Nope, that explains it....thanks. I only removed the mag plug for the oil, and the tranny plug for the tranny...although for half an hour i couldnt figure it out, since the plugs are all in the same area, and the little manual they give you is useless. Thanks alot.
so that's where the dead cat is....Damn never thought to look there...Dirty Jim said:
MAGnetic drain plug (the one you should remove to drain the engine oil).Randy Ontiveros said:Hi Jim,
What's a "mag plug" ?
Randy
