Just finished a 95" rebuild on my carbed 04 superglide.Threw in a set of andrews 37's too.Don't like the performance with the v&h big shots,poor dyno #'s.After alot of reading the cycle shack slip ons seem like they perform well and sound ok.Any opinions on which would perform best with the stock pipes and should I go with the 1 3/4 ,2 or 2 1/2?
Not sure on which size you need, but the "M" series, tapered is the hot set up for performance with stock head pipes.
Livin' Free Indeed
You want the Cycle Shack M slip-ons, 1 3/4". I don't think your problem is with the pipes though. I've had both pipes on my '02 FXDL at 95" with 44 CV carb, 37G cams & head work & the Big Shot staggered pipes with the power chamber crossover.
The BSS pipes actually had a little higher peak #s than the CS slip-ons though they also had a little more of a rich AFR torque dip at around 2500 RPM or so. I posted dyno sheets a few years ago as I tried getting rid of the rich AFR dip with Thunder Monster baffles, didn't work. Overall they are decent 2-2 pipes. A friend has them on his SE 103" & that bike is a tq monster.
I tried the CSs just to see what they would do & since there wasn't much difference I just left them on & sold the BSSs to a neighbor.
My big shots have NO crossover pipe.That seems to be the problem,I'm hoping......
